Part Number: CDCE6214-Q1EVM
This is an inquiry from our customer.
Using TICS.Pro to write the settings to EEPROM with the .tcs file open will result in an error.
Is this operation correct?
There is no problem in writing the .hxt file to the EEPROM and reading it and saving it as the .hxt file. So, it seems that there is no problem with the connection with USB ANY2.
Can you tell us something from the attached error message?
On the other hand, after reading the .tccs file, pressing "Write All Regs" seems to be able to write.
Is it possible to write to EEPROM by this operation?
My customer inquired because it is necessary to send this IC to the END user after writing the data to the EEPROM using EVM.
What is the correct procedure for writing data from a .tcs file to EEPROM?
Hiroshi
