The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LMK00306: DC Current Path on Outputs with AC-coupling and internal termination
Part Number: LMK00306
We're considering this part for a new design, but we concerned about the DC current path requirement between the differential outputs.
In our design, this chip would be driving a large-scale FPGA reference clock that requires AC-coupling and uses internal 100 ohm termination. The requirement to use 100-ohm term before the AC-coupling is problematic. Is it possible to use a larger valued resistor before the AC-coupling to satisfy the DC current path requirement? If so, what value should be used?
