TICSPRO-SW: USB2ANY firmware
Part Number: TICSPRO-SW
Other Parts Discussed in Thread: USB2ANY
Hi support team.
I have a question regarding following thread.
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/938491/ticspro-sw-ticspro-sw-doesn-t-work-with-usb2any-firmware-version-2-8-2-0?tisearch=e2e-sitesearch&keymatch=TICSPRO-SW#
Even with the latest version(1.7.5.7) of TICSPRO-SW, is USB2ANY firmware Ver2.7 or later unusable?
Higa
  • Higa-san,
    As of most recent versions of TICS Pro, we have begun bundling a new version of the firmware, v2.9.1.1, which includes substantial improvements to read and write speeds for almost all devices. v2.9.1.1 of USB2ANY firmware is now the supported version and we strongly encourage its use over older firmware versions.
    In theory, TICS Pro should also work with v2.7.0.0 and v2.8.2.0 versions of the DLL now, though faster block read and block write features will be missing. If a previous revision of the DLL is required:
    • Navigate to the TICS Pro installation folder (default C:\Program Files (x86)\Texas Instruments\TICS Pro)
    • Replace the USB2ANY.dll version in this folder with the version you would like to use
    • On startup of the application, navigate to the options menu and disable block reads/writes.
    Derek Payne
  • Hi Derek-san
    Thank you for answering.
    Is my understanding that the latest version of TICSPRO(1.7.5.7)  have supported v2.9.1.1 of USB2ANY correct?
    Currently,  we are experiencing an issue where we cannot write or read registers when connecting to the LMK04803BEVM.
    Higa
