Other Parts Discussed in Thread: TEST2
I want 38.4Mhz clock output and sync output via LMK04228.
OSCin uses 122.88Mhz and CLKin uses 38.4Mhz.
I want an output for the sync pulse based on the sync pulse input.
Figure 5. Curious how to set up TICS to use separate inputs and outputs simultaneously, such as the device and SYSREF clock output blocks from the datasheet.
My tcs file is attached below.
