Part Number: LMX2572
Other Parts Discussed in Thread: LMX2595, , LMX2594
Not sure this is the right forum for this question.
We are currently using the LMX2572 in a design. Due to limited part availability, would the LMX2595 be a direct drop in for the LMX2572? The charge pump LPF would need to be changed so I am not suggesting that it is a direct drop in with zero prep work.
The pkg outline shows this to be the case:
I am concerned that the electrical aspect will not be correct since they probably have different VCOs (hence different tune constants). We currently are using the LMX2572 with a 4 component Vtune LPF ( I believe this is a 3rd order). The datasheet for the LMX2595 suggest a 7 component Vtune LPF (I belive this is a 5th order, maybe a little higher). What is the downside of using a lower order charge pump filter, mostly spurious products suppression?
Also the output RF signals are biased a bit differently. Is this a mandatory requirement?
thanks
dennis brown
