Part Number: LMX2592
Hi Team,
Can you help clarify the question below?:
The datasheet states that the output of LMX2592 can be muted by setting OUTA_PD or the other channel as below. If channel A is muted by sending a power down command to its buffer, for example. how much time is needed for the transition from enable to power down and also from power down to enable?
Table 7-41. R46 Register Field Descriptions
7 OUTB_PD R/W 1 Output buffer B power down
1: power down
0: power up
6 OUTA_PD R/W 0 Output buffer A power down
1: power down
0: power up
I hope you can help.
Marvin
