Part Number: LMK03328
Hello team,
My customer have a quick question about downloading EEPROM data.
For manufacturing, they want to confirm if the data has downloaded well or not.
Does LMK03328 have such a function?
Austin
Hello team,
Austin
Austin,
I will look into this and provide you with a response by Tuesday.
Kadeem
Austin,
Please see below (from page 58 of the datasheet) pertaining to how to read from the EEPROM:
The EEPROM map can be found on page 123 of the datasheet: https://www.ti.com/lit/ds/symlink/lmk03328.pdf#page=123
Once the EEPROM is written to (per the procedure on page 57 of the datasheet: https://www.ti.com/lit/ds/symlink/lmk03328.pdf#page=57), they can read back each bit in the EEPROM and compare it to the expected value. If the values are not identical, then there may be an issue with their write procedure. Note that some of these bits/registers are reserved.
Kadeem
