LMK03806: 0x11(R17) regiater controls
Guru 11400 points
Part Number: LMK03806
My customer is using the LMK03806.
When reviewing the register settings of the LMK03806 in use, the customer found that the following controls were performed at the end of the settings.
If this control is removed, the LMK03806 did not work normally.
0x11(R17) : 0x3401101b
0x11(R17) : 0x3400101b
Please tell us what this control does and what the R17 register does.
Thank you.
JH
  • Hi JH,
    I couldn't find a description of register R17 in the datasheet and it is hidden in the TICS Pro profile for the LMK03806. Generally this means that it is a reserved register that should not be modified by customers. Could you clarify what you mean by "register settings of the LMK03806 in use"? Is this a set of instructions from the device itself or written by the customer?
    Evan Su
