The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LMK5C33216: LVPECL Output Frequency
Part Number: LMK5C33216
LMK5C33216's data sheet defines 1,000 MHz as the Max LVPECL output frequency. I guess it means the LMK5C33216 can generate LVPECL clocks of up to at least 1,000 MHz. The data sheet also adds, "(2) An output frequency over the fOUT max spec is possible, but the output swing may be less than the VOD min spec," as a note in the section 7.5 Electrical Characteristics. How high can the LMK5C33216 generate LVPECL output frequency practically? Do you have a performance plot of LVPECL fOUT vs VOD, for example?
Shinichi Yokota
