Part Number: LMX2694-SEP
Is there any method for higher power than the characteristics in the datasheet?
In the datasheet, Pout is 2dBm at fout=8GHz.
can it be increased up to 6dBm with any work around?
Thanks.
Thanks.
Hi David, our expert on this topic is Ooo today, he will get back to you promptly next week.
Juan
Hi David,
LMX2694-SEP output power can be improved using the inductor pull up at RFout pins.
Follow the section 8.1.4 in datasheet, explains the various options for the pull ups.
Thanks!
Ajeet Pal
Hi Ajeet,
Is there any method to increase typical power of LMX2694-SEP?
Thanks.
Hi David,
The typical power is at the recommendation setting of OUTx_PWR (31) and this can't be increase much.
Thanks!
Ajeet Pal
