CDCE62005 Unused Inputs
Other Parts Discussed in Thread: CDCE62005
I'm only using the PRI (+/-) inputs on the CDCE62005. Can I leave SEC and EXT_LF inputs floating, or should these be tied? If tied, what's recommended?
    You can leave EXT_LF pins floating if you are not using external loop filter.
    For unused SEC_REF inputs, here is the recommendation
    - Pull down SEC_REF- pin  to GND through 1k resistor
    - Pull up  SEC_REF+ pin to VCC through 1k resistor
    Firoj
