Part Number: LMK00301
Hi Team,
As far as i can see in order to configure the different outputs banks of the buffer you have to send either '1' or '0' the the designated pins.
Since this device is the clock source for my FPGA when startup i want to make sure that the FPGA gets the clock in a predefine type.
Is it possible to tie the inputs either to ground or to a pull-up to configure the output "manually"
best regards
