Part Number: CDCE913
Hi, Support Team
We will use CDCE913 and TS5A63518 as below chart
Please help to review and advise.
Thank you.
Lawrence
Hi, Support Team
Thank you.
Lawrence
Lawrence,
Ensure that you have pullup resistors for the I2C connections. Make sure that the traces to the other devices are impedance matched - a 22-Ohm resistor is series with the output trace is recommended. For best performance, it is recommended to isolate the VDD and VDDOUT supplies using a ferrite bead.
Kadeem
Hi, Kadeem
i revised the schematic as your recommended like this? is correct?
if any suggestion, Please advise me.
Lawrence
Lawrence,
If the circles indicate that these will change, then you are good.
Kadeem
Hi, Kedeem
we will selection of a ferrite bead on the following three parameter:
DC impendance(0 to 5ohm)
DC current( 15% margin + max supply current)
resonance near low freuency(10-100kHz)
if any, Please advise me.
Lawrence
Lawrence,
On the CDCE(L)9XX Performance Evaluation Module, we use the BLM31PG500SN1L, though this has a 50 ohm impedance.
The BLM21BB050SN1D may be suitable for your requirements.
Kadeem
