Part Number: TLC555M
Is there any radiation data (TID and/or SEE) for this part? Thanks.
Hi Peter,
We do not collect radiation data for non-RHA devices. The only devices for which we collect radiation data have -SP or -SEP suffixes.
Zach
Thanks. It looks like my reply with additional questions got lost. I see that the lid is nickel plated ceramic, if that is true is it grounded? And can you confirm whether the pads are plated Au or SnPb? I've seen it described both ways, thanks.
Hi Peter,
I believe you are referring to TLC555MFKB in the 20-pin leadless LCCC package? If so, you are correct the lid is nickel-plated ceramic and the pad/lead finish is SnPb.
I'm looking into your question about the lid potential and so far I haven't been able to find a definitive answer. It may take a day or two to track down the proper documentation. Will let you know when I have an update.
Zach
Hi Peter,
Thanks for the confirmation. I've reached out to the product engineers covering this device, they should have access to the internal bond wiring and packaging information. Although It's likely I won't hear anything back after the 4th.
Enjoy your holiday weekend.
Zach
Hi Peter,
I received confirmation that the lid is not connected to any pin and is floating.
Zach
