I have four LMX2820 synthesiezer on my board. I used four CE signal and four CS# signal for each of LMX2820. and I used just one SDI signal and one MUXOUT signal to control all of them.
For example, I selecte one synthesizer by enable the related CE signal and CS# signal, then sent the SDI signal to programming it. it works good for SDI signal. the reg value on the GUI looks programmed and I can see the output looks right as I want. However, when I want to readback the register information by by click the "read resgiter" on the GUI, I will see the register became to 0. I checked the MUXOUT pin on the LMX2820, the waveform looks good to me. Could you let me know why I can not read the register value?
Wei
