LMK03318: The clock synthesizer IC is not giving any output frequency
Part Number: LMK03318
The IC LMK03318rhsr is used in my case to provide 6 output frequencies.The input to this IC is PRIREF_P of 25MHz.
Using TICS Pro software when I try "I2C scan", I can see the device address to be 0x53.
I can read/write registers. I even wrote to page0 of EEPROM of clock synthesizer.
In the hardware end , when I probe the input port I can see 25MHz but on the output I am not seeing any frequency.
Can anyone please tell me why this behavior is observed?
The GPIO configuration that I have kept in the hardware is :
GPIO 0 = high
GPIO1 = high
GPIO2 = low
GPIO3= low
GPIO4 = high
GPIO5 = high
Other pin configurations are:-
HW_CTRL = low
REFSEL1 = low
PDN = high
status0  = high
status1 = high
Sameeksh Shetty
  • There are few observations regarding this:
    1. In TICS pro, whenever the "Output" section I make the output muxes as 'PRIREF'. And write the registers using this, I can see that frequency at the output.
    2. STATUS0 and STATUS1 pins are high
    In the "PLL" section if I keep the Gain as 0mA then only I am see the output frequencies.
    But the frequencies are almost half of the expected value.
    So my tweaking the divider ratio I was able to get proper output frequencies.
    Now when I write this into EEPROM and toggle the PDN pin, after the power cycle I am not seeing any output frequency.
    These are the configurations that I have kept in TICS pro:
    Please let me know if I am missing some configurations here.
    Sameeksh Shetty
  • Hi some more info I need to share here,
    1.After writing into EEPROM , when I probe STATUS1 pin , I am seeing the signal is toggling
    In this case I am seeing the proper frequencies.
    Below image shows this condition.
    2.But after power cycle , The STATUS1 pin is high (its not toggling).
    And I am not seeing any output frequencies.
    3.Now to confirm that eeprom data remains the same before and after the power cycle, I did Export EEPROM ->GUI. Then saved the file in text format.
    I am sharing the file here
    [EEPROM_IMAGE]
    COUNT=345
    DATE_TIME=2023-07-14, 20:58:41
    DESIGN_NAME=Enter Design Name
    USER_NOTES=Enter User Notes
    EEPROM_IMG_IDX00=1
    EEPROM_IMG_IDX01=1
    EEPROM_IMG_IDX02=89
    EEPROM_IMG_IDX03=171
    EEPROM_IMG_IDX04=31
    EEPROM_IMG_IDX05=1
    EEPROM_IMG_IDX06=2
    EEPROM_IMG_IDX07=31
    EEPROM_IMG_IDX08=240
    EEPROM_IMG_IDX09=33
    EEPROM_IMG_IDX10=255
    EEPROM_IMG_IDX11=160
    EEPROM_IMG_IDX12=0
    EEPROM_IMG_IDX13=232
    EEPROM_IMG_IDX14=232
    EEPROM_IMG_IDX15=0
    EEPROM_IMG_IDX16=7
    EEPROM_IMG_IDX17=255
    EEPROM_IMG_IDX18=255
    EEPROM_IMG_IDX19=254
    EEPROM_IMG_IDX20=7
    EEPROM_IMG_IDX21=168
    EEPROM_IMG_IDX22=7
    EEPROM_IMG_IDX23=26
    EEPROM_IMG_IDX24=100
    EEPROM_IMG_IDX25=172
    EEPROM_IMG_IDX26=189
    EEPROM_IMG_IDX27=209
    EEPROM_IMG_IDX28=117
    EEPROM_IMG_IDX29=73
    EEPROM_IMG_IDX30=133
    EEPROM_IMG_IDX31=0
    EEPROM_IMG_IDX32=5
    EEPROM_IMG_IDX33=209
    EEPROM_IMG_IDX34=157
    EEPROM_IMG_IDX35=25
    EEPROM_IMG_IDX36=82
    EEPROM_IMG_IDX37=0
    EEPROM_IMG_IDX38=0
    EEPROM_IMG_IDX39=48
    EEPROM_IMG_IDX40=192
    EEPROM_IMG_IDX41=57
    EEPROM_IMG_IDX42=134
    EEPROM_IMG_IDX43=1
    EEPROM_IMG_IDX44=198
    EEPROM_IMG_IDX45=1
    EEPROM_IMG_IDX46=198
    EEPROM_IMG_IDX47=1
    EEPROM_IMG_IDX48=198
    EEPROM_IMG_IDX49=1
    EEPROM_IMG_IDX50=198
    EEPROM_IMG_IDX51=1
    EEPROM_IMG_IDX52=194
    EEPROM_IMG_IDX53=128
    EEPROM_IMG_IDX54=0
    EEPROM_IMG_IDX55=0
    EEPROM_IMG_IDX56=40
    EEPROM_IMG_IDX57=68
    EEPROM_IMG_IDX58=24
    EEPROM_IMG_IDX59=8
    EEPROM_IMG_IDX60=3
    EEPROM_IMG_IDX61=136
    EEPROM_IMG_IDX62=4
    EEPROM_IMG_IDX63=32
    EEPROM_IMG_IDX64=0
    EEPROM_IMG_IDX65=0
    EEPROM_IMG_IDX66=0
    EEPROM_IMG_IDX67=0
    EEPROM_IMG_IDX68=1
    EEPROM_IMG_IDX69=193
    EEPROM_IMG_IDX70=8
    EEPROM_IMG_IDX71=0
    EEPROM_IMG_IDX72=16
    EEPROM_IMG_IDX73=0
    EEPROM_IMG_IDX74=0
    EEPROM_IMG_IDX75=0
    EEPROM_IMG_IDX76=0
    EEPROM_IMG_IDX77=0
    EEPROM_IMG_IDX78=0
    EEPROM_IMG_IDX79=0
    EEPROM_IMG_IDX80=0
    EEPROM_IMG_IDX81=0
    EEPROM_IMG_IDX82=0
    EEPROM_IMG_IDX83=1
    EEPROM_IMG_IDX84=40
    EEPROM_IMG_IDX85=24
    EEPROM_IMG_IDX86=6
    EEPROM_IMG_IDX87=163
    EEPROM_IMG_IDX88=3
    EEPROM_IMG_IDX89=56
    EEPROM_IMG_IDX90=48
    EEPROM_IMG_IDX91=192
    EEPROM_IMG_IDX92=57
    EEPROM_IMG_IDX93=134
    EEPROM_IMG_IDX94=1
    EEPROM_IMG_IDX95=198
    EEPROM_IMG_IDX96=1
    EEPROM_IMG_IDX97=198
    EEPROM_IMG_IDX98=2
    EEPROM_IMG_IDX99=70
    EEPROM_IMG_IDX100=2
    EEPROM_IMG_IDX101=70
    EEPROM_IMG_IDX102=2
    EEPROM_IMG_IDX103=68
    EEPROM_IMG_IDX104=12
    EEPROM_IMG_IDX105=64
    EEPROM_IMG_IDX106=0
    EEPROM_IMG_IDX107=42
    EEPROM_IMG_IDX108=4
    EEPROM_IMG_IDX109=24
    EEPROM_IMG_IDX110=0
    EEPROM_IMG_IDX111=3
    EEPROM_IMG_IDX112=152
    EEPROM_IMG_IDX113=3
    EEPROM_IMG_IDX114=32
    EEPROM_IMG_IDX115=0
    EEPROM_IMG_IDX116=0
    EEPROM_IMG_IDX117=0
    EEPROM_IMG_IDX118=0
    EEPROM_IMG_IDX119=1
    EEPROM_IMG_IDX120=193
    EEPROM_IMG_IDX121=8
    EEPROM_IMG_IDX122=78
    EEPROM_IMG_IDX123=20
    EEPROM_IMG_IDX124=0
    EEPROM_IMG_IDX125=0
    EEPROM_IMG_IDX126=0
    EEPROM_IMG_IDX127=0
    EEPROM_IMG_IDX128=0
    EEPROM_IMG_IDX129=0
    EEPROM_IMG_IDX130=0
    EEPROM_IMG_IDX131=0
    EEPROM_IMG_IDX132=0
    EEPROM_IMG_IDX133=0
    EEPROM_IMG_IDX134=1
    EEPROM_IMG_IDX135=32
    EEPROM_IMG_IDX136=32
    EEPROM_IMG_IDX137=14
    EEPROM_IMG_IDX138=163
    EEPROM_IMG_IDX139=3
    EEPROM_IMG_IDX140=56
    EEPROM_IMG_IDX141=48
    EEPROM_IMG_IDX142=192
    EEPROM_IMG_IDX143=57
    EEPROM_IMG_IDX144=134
    EEPROM_IMG_IDX145=2
    EEPROM_IMG_IDX146=70
    EEPROM_IMG_IDX147=2
    EEPROM_IMG_IDX148=70
    EEPROM_IMG_IDX149=2
    EEPROM_IMG_IDX150=70
    EEPROM_IMG_IDX151=2
    EEPROM_IMG_IDX152=70
    EEPROM_IMG_IDX153=2
    EEPROM_IMG_IDX154=68
    EEPROM_IMG_IDX155=12
    EEPROM_IMG_IDX156=64
    EEPROM_IMG_IDX157=0
    EEPROM_IMG_IDX158=42
    EEPROM_IMG_IDX159=4
    EEPROM_IMG_IDX160=24
    EEPROM_IMG_IDX161=0
    EEPROM_IMG_IDX162=3
    EEPROM_IMG_IDX163=152
    EEPROM_IMG_IDX164=3
    EEPROM_IMG_IDX165=32
    EEPROM_IMG_IDX166=0
    EEPROM_IMG_IDX167=0
    EEPROM_IMG_IDX168=0
    EEPROM_IMG_IDX169=0
    EEPROM_IMG_IDX170=1
    EEPROM_IMG_IDX171=193
    EEPROM_IMG_IDX172=8
    EEPROM_IMG_IDX173=78
    EEPROM_IMG_IDX174=20
    EEPROM_IMG_IDX175=0
    EEPROM_IMG_IDX176=0
    EEPROM_IMG_IDX177=0
    EEPROM_IMG_IDX178=0
    EEPROM_IMG_IDX179=0
    EEPROM_IMG_IDX180=0
    EEPROM_IMG_IDX181=0
    EEPROM_IMG_IDX182=0
    EEPROM_IMG_IDX183=0
    EEPROM_IMG_IDX184=0
    EEPROM_IMG_IDX185=1
    EEPROM_IMG_IDX186=32
    EEPROM_IMG_IDX187=32
    EEPROM_IMG_IDX188=14
    EEPROM_IMG_IDX189=163
    EEPROM_IMG_IDX190=3
    EEPROM_IMG_IDX191=56
    EEPROM_IMG_IDX192=48
    EEPROM_IMG_IDX193=192
    EEPROM_IMG_IDX194=57
    EEPROM_IMG_IDX195=134
    EEPROM_IMG_IDX196=1
    EEPROM_IMG_IDX197=198
    EEPROM_IMG_IDX198=12
    EEPROM_IMG_IDX199=70
    EEPROM_IMG_IDX200=12
    EEPROM_IMG_IDX201=70
    EEPROM_IMG_IDX202=12
    EEPROM_IMG_IDX203=70
    EEPROM_IMG_IDX204=12
    EEPROM_IMG_IDX205=66
    EEPROM_IMG_IDX206=128
    EEPROM_IMG_IDX207=0
    EEPROM_IMG_IDX208=0
    EEPROM_IMG_IDX209=41
    EEPROM_IMG_IDX210=4
    EEPROM_IMG_IDX211=24
    EEPROM_IMG_IDX212=0
    EEPROM_IMG_IDX213=3
    EEPROM_IMG_IDX214=152
    EEPROM_IMG_IDX215=6
    EEPROM_IMG_IDX216=64
    EEPROM_IMG_IDX217=0
    EEPROM_IMG_IDX218=0
    EEPROM_IMG_IDX219=0
    EEPROM_IMG_IDX220=0
    EEPROM_IMG_IDX221=1
    EEPROM_IMG_IDX222=193
    EEPROM_IMG_IDX223=8
    EEPROM_IMG_IDX224=78
    EEPROM_IMG_IDX225=20
    EEPROM_IMG_IDX226=0
    EEPROM_IMG_IDX227=0
    EEPROM_IMG_IDX228=0
    EEPROM_IMG_IDX229=0
    EEPROM_IMG_IDX230=0
    EEPROM_IMG_IDX231=0
    EEPROM_IMG_IDX232=0
    EEPROM_IMG_IDX233=0
    EEPROM_IMG_IDX234=0
    EEPROM_IMG_IDX235=0
    EEPROM_IMG_IDX236=5
    EEPROM_IMG_IDX237=8
    EEPROM_IMG_IDX238=40
    EEPROM_IMG_IDX239=14
    EEPROM_IMG_IDX240=163
    EEPROM_IMG_IDX241=3
    EEPROM_IMG_IDX242=56
    EEPROM_IMG_IDX243=48
    EEPROM_IMG_IDX244=192
    EEPROM_IMG_IDX245=57
    EEPROM_IMG_IDX246=134
    EEPROM_IMG_IDX247=1
    EEPROM_IMG_IDX248=198
    EEPROM_IMG_IDX249=1
    EEPROM_IMG_IDX250=198
    EEPROM_IMG_IDX251=12
    EEPROM_IMG_IDX252=70
    EEPROM_IMG_IDX253=12
    EEPROM_IMG_IDX254=118
    EEPROM_IMG_IDX255=0
    EEPROM_IMG_IDX256=2
    EEPROM_IMG_IDX257=128
    EEPROM_IMG_IDX258=0
    EEPROM_IMG_IDX259=0
    EEPROM_IMG_IDX260=42
    EEPROM_IMG_IDX261=4
    EEPROM_IMG_IDX262=24
    EEPROM_IMG_IDX263=0
    EEPROM_IMG_IDX264=3
    EEPROM_IMG_IDX265=152
    EEPROM_IMG_IDX266=6
    EEPROM_IMG_IDX267=64
    EEPROM_IMG_IDX268=0
    EEPROM_IMG_IDX269=0
    EEPROM_IMG_IDX270=0
    EEPROM_IMG_IDX271=0
    EEPROM_IMG_IDX272=1
    EEPROM_IMG_IDX273=193
    EEPROM_IMG_IDX274=8
    EEPROM_IMG_IDX275=78
    EEPROM_IMG_IDX276=20
    EEPROM_IMG_IDX277=0
    EEPROM_IMG_IDX278=0
    EEPROM_IMG_IDX279=0
    EEPROM_IMG_IDX280=0
    EEPROM_IMG_IDX281=0
    EEPROM_IMG_IDX282=0
    EEPROM_IMG_IDX283=0
    EEPROM_IMG_IDX284=0
    EEPROM_IMG_IDX285=0
    EEPROM_IMG_IDX286=0
    EEPROM_IMG_IDX287=4
    EEPROM_IMG_IDX288=0
    EEPROM_IMG_IDX289=40
    EEPROM_IMG_IDX290=14
    EEPROM_IMG_IDX291=163
    EEPROM_IMG_IDX292=3
    EEPROM_IMG_IDX293=56
    EEPROM_IMG_IDX294=89
    EEPROM_IMG_IDX295=96
    EEPROM_IMG_IDX296=130
    EEPROM_IMG_IDX297=203
    EEPROM_IMG_IDX298=4
    EEPROM_IMG_IDX299=4
    EEPROM_IMG_IDX300=4
    EEPROM_IMG_IDX301=2
    EEPROM_IMG_IDX302=4
    EEPROM_IMG_IDX303=2
    EEPROM_IMG_IDX304=4
    EEPROM_IMG_IDX305=15
    EEPROM_IMG_IDX306=132
    EEPROM_IMG_IDX307=2
    EEPROM_IMG_IDX308=128
    EEPROM_IMG_IDX309=0
    EEPROM_IMG_IDX310=0
    EEPROM_IMG_IDX311=42
    EEPROM_IMG_IDX312=4
    EEPROM_IMG_IDX313=24
    EEPROM_IMG_IDX314=0
    EEPROM_IMG_IDX315=2
    EEPROM_IMG_IDX316=152
    EEPROM_IMG_IDX317=6
    EEPROM_IMG_IDX318=96
    EEPROM_IMG_IDX319=0
    EEPROM_IMG_IDX320=0
    EEPROM_IMG_IDX321=0
    EEPROM_IMG_IDX322=0
    EEPROM_IMG_IDX323=1
    EEPROM_IMG_IDX324=193
    EEPROM_IMG_IDX325=8
    EEPROM_IMG_IDX326=78
    EEPROM_IMG_IDX327=20
    EEPROM_IMG_IDX328=0
    EEPROM_IMG_IDX329=0
    EEPROM_IMG_IDX330=0
    EEPROM_IMG_IDX331=0
    EEPROM_IMG_IDX332=0
    EEPROM_IMG_IDX333=0
    EEPROM_IMG_IDX334=0
    EEPROM_IMG_IDX335=0
    EEPROM_IMG_IDX336=0
    EEPROM_IMG_IDX337=0
    EEPROM_IMG_IDX338=4
    EEPROM_IMG_IDX339=0
    EEPROM_IMG_IDX340=43
    EEPROM_IMG_IDX341=14
    EEPROM_IMG_IDX342=163
    EEPROM_IMG_IDX343=3
    EEPROM_IMG_IDX344=56
    [EEPROM_IMAGE]
    COUNT=345
    DATE_TIME=2023-07-14, 20:53:41
    EEPROM_IMG_IDX00=1
    EEPROM_IMG_IDX01=1
    EEPROM_IMG_IDX02=89
    EEPROM_IMG_IDX04=31
    EEPROM_IMG_IDX05=1
    EEPROM_IMG_IDX06=2
    EEPROM_IMG_IDX07=31
    EEPROM_IMG_IDX09=33
    EEPROM_IMG_IDX12=0
    EEPROM_IMG_IDX15=0
    EEPROM_IMG_IDX16=7
    EEPROM_IMG_IDX20=7
    EEPROM_IMG_IDX22=7
    EEPROM_IMG_IDX23=26
    EEPROM_IMG_IDX29=73
    EEPROM_IMG_IDX31=0
    EEPROM_IMG_IDX32=5
    EEPROM_IMG_IDX35=25
    EEPROM_IMG_IDX36=82
    EEPROM_IMG_IDX37=0
    EEPROM_IMG_IDX38=0
    EEPROM_IMG_IDX39=48
    EEPROM_IMG_IDX41=57
    EEPROM_IMG_IDX43=1
    EEPROM_IMG_IDX45=1
    EEPROM_IMG_IDX47=1
    EEPROM_IMG_IDX49=1
    EEPROM_IMG_IDX51=1
    EEPROM_IMG_IDX54=0
    EEPROM_IMG_IDX55=0
    EEPROM_IMG_IDX56=40
    EEPROM_IMG_IDX57=68
    EEPROM_IMG_IDX58=24
    EEPROM_IMG_IDX59=8
    EEPROM_IMG_IDX60=3
    EEPROM_IMG_IDX62=4
    EEPROM_IMG_IDX63=32
    EEPROM_IMG_IDX64=0
    EEPROM_IMG_IDX65=0
    EEPROM_IMG_IDX66=0
    EEPROM_IMG_IDX67=0
    EEPROM_IMG_IDX68=1
    EEPROM_IMG_IDX70=8
    EEPROM_IMG_IDX71=0
    EEPROM_IMG_IDX72=16
    EEPROM_IMG_IDX73=0
    EEPROM_IMG_IDX74=0
    EEPROM_IMG_IDX75=0
    EEPROM_IMG_IDX76=0
    EEPROM_IMG_IDX77=0
    EEPROM_IMG_IDX78=0
    EEPROM_IMG_IDX79=0
    EEPROM_IMG_IDX80=0
    EEPROM_IMG_IDX81=0
    EEPROM_IMG_IDX82=0
    EEPROM_IMG_IDX83=1
    EEPROM_IMG_IDX84=40
    EEPROM_IMG_IDX85=24
    EEPROM_IMG_IDX86=6
    EEPROM_IMG_IDX88=3
    EEPROM_IMG_IDX89=56
    EEPROM_IMG_IDX90=48
    EEPROM_IMG_IDX92=57
    EEPROM_IMG_IDX94=1
    EEPROM_IMG_IDX96=1
    EEPROM_IMG_IDX98=2
    EEPROM_IMG_IDX99=70
    EEPROM_IMG_IDX100=2
    EEPROM_IMG_IDX102=2
    EEPROM_IMG_IDX106=0
    EEPROM_IMG_IDX108=4
    EEPROM_IMG_IDX110=0
    EEPROM_IMG_IDX111=3
    EEPROM_IMG_IDX113=3
    EEPROM_IMG_IDX115=0
    EEPROM_IMG_IDX116=0
    EEPROM_IMG_IDX117=0
    EEPROM_IMG_IDX118=0
    EEPROM_IMG_IDX119=1
    EEPROM_IMG_IDX121=8
    EEPROM_IMG_IDX124=0
    EEPROM_IMG_IDX125=0
    EEPROM_IMG_IDX126=0
    EEPROM_IMG_IDX127=0
    EEPROM_IMG_IDX128=0
    EEPROM_IMG_IDX129=0
    EEPROM_IMG_IDX130=0
    EEPROM_IMG_IDX131=0
    EEPROM_IMG_IDX132=0
    EEPROM_IMG_IDX133=0
    EEPROM_IMG_IDX134=1
    EEPROM_IMG_IDX139=3
    EEPROM_IMG_IDX145=2
    EEPROM_IMG_IDX147=2
    EEPROM_IMG_IDX149=2
    EEPROM_IMG_IDX151=2
    EEPROM_IMG_IDX153=2
    EEPROM_IMG_IDX157=0
    EEPROM_IMG_IDX159=4
    EEPROM_IMG_IDX161=0
    EEPROM_IMG_IDX162=3
    EEPROM_IMG_IDX164=3
    EEPROM_IMG_IDX166=0
    EEPROM_IMG_IDX167=0
    EEPROM_IMG_IDX168=0
    EEPROM_IMG_IDX169=0
    EEPROM_IMG_IDX170=1
    EEPROM_IMG_IDX172=8
    EEPROM_IMG_IDX175=0
    EEPROM_IMG_IDX176=0
    EEPROM_IMG_IDX177=0
    EEPROM_IMG_IDX178=0
    EEPROM_IMG_IDX179=0
    EEPROM_IMG_IDX180=0
    EEPROM_IMG_IDX181=0
    EEPROM_IMG_IDX182=0
    EEPROM_IMG_IDX183=0
    EEPROM_IMG_IDX184=0
    EEPROM_IMG_IDX185=1
    EEPROM_IMG_IDX190=3
    EEPROM_IMG_IDX196=1
    EEPROM_IMG_IDX207=0
    EEPROM_IMG_IDX208=0
    EEPROM_IMG_IDX210=4
    EEPROM_IMG_IDX212=0
    EEPROM_IMG_IDX213=3
    EEPROM_IMG_IDX215=6
    EEPROM_IMG_IDX217=0
    EEPROM_IMG_IDX218=0
    EEPROM_IMG_IDX219=0
    EEPROM_IMG_IDX220=0
    EEPROM_IMG_IDX221=1
    EEPROM_IMG_IDX223=8
    EEPROM_IMG_IDX226=0
    EEPROM_IMG_IDX227=0
    EEPROM_IMG_IDX228=0
    EEPROM_IMG_IDX229=0
    EEPROM_IMG_IDX230=0
    EEPROM_IMG_IDX231=0
    EEPROM_IMG_IDX232=0
    EEPROM_IMG_IDX233=0
    EEPROM_IMG_IDX234=0
    EEPROM_IMG_IDX235=0
    EEPROM_IMG_IDX236=5
    EEPROM_IMG_IDX237=8
    EEPROM_IMG_IDX241=3
    EEPROM_IMG_IDX247=1
    EEPROM_IMG_IDX249=1
    EEPROM_IMG_IDX255=0
    EEPROM_IMG_IDX256=2
    EEPROM_IMG_IDX258=0
    EEPROM_IMG_IDX259=0
    EEPROM_IMG_IDX261=4
    EEPROM_IMG_IDX263=0
    EEPROM_IMG_IDX264=3
    EEPROM_IMG_IDX266=6
    EEPROM_IMG_IDX268=0
    EEPROM_IMG_IDX269=0
    EEPROM_IMG_IDX270=0
    EEPROM_IMG_IDX271=0
    EEPROM_IMG_IDX272=1
    EEPROM_IMG_IDX274=8
    EEPROM_IMG_IDX277=0
    EEPROM_IMG_IDX278=0
    EEPROM_IMG_IDX279=0
    EEPROM_IMG_IDX280=0
    EEPROM_IMG_IDX281=0
    EEPROM_IMG_IDX282=0
    EEPROM_IMG_IDX283=0
    EEPROM_IMG_IDX284=0
    EEPROM_IMG_IDX285=0
    EEPROM_IMG_IDX286=0
    EEPROM_IMG_IDX287=4
    EEPROM_IMG_IDX288=0
    EEPROM_IMG_IDX292=3
    EEPROM_IMG_IDX298=4
    EEPROM_IMG_IDX299=4
    EEPROM_IMG_IDX300=4
    EEPROM_IMG_IDX301=2
    EEPROM_IMG_IDX302=4
    EEPROM_IMG_IDX303=2
    EEPROM_IMG_IDX304=4
    EEPROM_IMG_IDX307=2
    EEPROM_IMG_IDX309=0
    EEPROM_IMG_IDX310=0
    EEPROM_IMG_IDX312=4
    EEPROM_IMG_IDX314=0
    EEPROM_IMG_IDX315=2
    EEPROM_IMG_IDX317=6
    EEPROM_IMG_IDX319=0
    EEPROM_IMG_IDX320=0
    EEPROM_IMG_IDX321=0
    EEPROM_IMG_IDX322=0
    EEPROM_IMG_IDX323=1
    EEPROM_IMG_IDX325=8
    EEPROM_IMG_IDX328=0
    EEPROM_IMG_IDX329=0
    EEPROM_IMG_IDX330=0
    EEPROM_IMG_IDX331=0
    EEPROM_IMG_IDX332=0
    EEPROM_IMG_IDX333=0
    EEPROM_IMG_IDX334=0
    EEPROM_IMG_IDX335=0
    EEPROM_IMG_IDX336=0
    EEPROM_IMG_IDX337=0
    EEPROM_IMG_IDX338=4
    EEPROM_IMG_IDX339=0
    EEPROM_IMG_IDX343=3
  • Hi Sameeksh,
    i am not able to load the file you provided in TICSpro.
    LMK03318's VCO frequency range is from 4.8 to 5.4 GHz, in your screen snippet i see the VCO is at 2.4 GHz.
    Using the input frequencies you provided in the GUI and the outputs I was able to create this config. Try this and let me know if it works.
    Vicente
     testConfig.tcs
  • Hi Vicente,
    Using the configuration you have given when I do "write all register" , I can see the exact frequency that is expected.
    But the problem remains the same. That when I write to the EEPROM page 5 and then power cycle(GPIO2=high,GPIO3=high) , I am not getting any of the frequencies at the output.
    These are the steps I followed to write the eeprom:-
    I think the eeprom configuration is somehow not read to the registers during POR.
  • Hi Sameeksh,
    Try programming the EEPROM by editing the raw registers directly.
    Vicente
  • Hi Vicente,
    In the TICS pro there are things that need to understand.
    The "User Control" section has some default configurations. What should I do regarding them, are they need to be changed/updated?!
  • Hi Vicente,
    The steps shown in "write SRAM" section and "write EEPROM" section does it involve any other thing to be done in EEPROM section of TICS Pro?
    The steps given here are confusing. Reason being that when I configure the EEPROM using "EEPROM" section of TICS pro, I can see the sram being written and then from there eeprom being written.
    But in this case I can see only few registers being written and it doesn't even take time.
    What exactly differs by configuring the eeprom using EEPROM section and Raw Register section?
    Why cant I use EEPROM section only?
  • Hi Vicente,
    I followed these steps:-
    1.Configured all the output frequencies in TICS pro. ( Input/PLL , PLL and Output section )
    Note:- PLL VCO should be in the range of 4.8GHz and 5.4GHz
    2.Hardware wise:-
    HW_SW_CTRL= low   (EEPROM)
    REFSEL_CLK= low     (Primary reference will be selected)
    GPIO2 = GPIO3 = low   (Page 0 of EEPROM)
    3.Followed the EEPROM writing section in TICS
    4.In the Raw Register section in TICS  [I got help regarding this from your msg]
    R144 as 0x90EA
    R137 as 0x8911
    R144 as 0x9000
    After following these steps now the EEPROM is retaining the config after the power-cycle.
    Sameeksh Shetty
