Other Parts Discussed in Thread: CDCE913
Does TI have a fractional-n pll with an internal VCO that can run at 75 MHz? I've looked and I can find a couple of integer-n but not fractional-n.
CDCE913 ( and other devices in this family) has fractional-N PLL, but VCO runs at 80 MHz minimum. The device has output divider. So, you can run the VCO at higher frequency (as for example 150 MHz) and generate 75 MHz.
Firoj
Firoj, any idea how a modulation scheme at the input could work with the part? The application uses the clock to communicate modulated data and the concern is that the internal loop filter may compensate this out. Any thoughts?
The concern is valid. The PLL has a few hundred kHz loop bandwidth - depending on PLL settings. So, there is possibility that modulated data can be filtered out.
Firoj
