Part Number: BQ4802LY
Hi team,
I wanted to make sure I correctly understand how the external CMOS SRAM should be attached to the BQ4802LY. I’m under the impression that CS is used strictly to select the RTC registers and CE_IN is used strictly to select the external SRAM IC via CE_OUT to allow for the use of the full address range of the SRAM IC, can you confirm?
Is there a recommended 32k x 8 SRAM IC that would be suitable to pair with this IC?
Ben
