CDCLVC1103: Clock buffer usage example
Guru 15210 points
Part Number: CDCLVC1103
We have placed an oscillator close to the ASIC, but we are considering using multiple ASICs in the future. I am considering whether it will work fine with just one oscillator for multiple ASICs, or whether it would be better to use a clock buffer. When do you need a clock buffer? I would like to know what concerns you have and how they can be resolved by adopting a clock buffer.
Conor
  • Hello Conor,
    For multiple ASICs, you for sure want one oscillator given the reference to a buffer and that buffer fanning out that frequency to multiple ASICs. If you only use one oscillator and route that signal to multiple ASICs, the swing/amplitude of your clock will change and therefore, may violate the swing requirements and add more noise for the clock being fed into the ASICs.
    In other words, this is a perfect example of when you would need a buffer. When you are trying to create several multiples of the same frequency. Let me know if you have any other questions.
    Good luck!
    Andrea
