Other Parts Discussed in Thread: CDCE62005
I want to use the CDCE62005 EVM board with a Win7 system. I saw in a previous post that the Win7 driver is not released yet. Can I get a preliminary version?
Thanks.
Thanks.
Brad, the new files are posted: http://e2e.ti.com/support/clocks/m/videos__files/353682.aspx
Good luck and let us know how it worked! BR. Fritz
Hi Fritz,
I installed the driver on my Win7-64 bit system and it did not work. When I uninstalled and reinstalled under device manager, it displayed a message that the driver was not designed (? I think that was the right verb?) for this platform. We tried installing on another clean Win7 machine and got the same results. Any ideas?
Thanks, Brad
Brad,
sorry for not having gotten back to you right away. I just went through installing the package myself on a clean notebook and was able to install the SW but failed when I connected the EVM.
I am checking with the experts currently and we can hopefully update you quickly.
Best regards, Fritz
Brad, we got a new driver version, and I tried it out and it works. Please plug your EVM in, then go to device manager, and uninstall the driver. Then unplug the EVM and plug it back in, and install the driver that you can download under the following link. We will also post a new installer later to E2E, but for now this should work for you and be quicker than installing the entire software again. BR. Fritz
5241.CDCE62005_64b_WIN7_Driver.zip
The software has now also been released as an installer under the "files" tab.
