Part Number: LMK04832
I wanted to use the OSCout/CLKin2 as auxiliary ref clock input. According to datasheet, the default function for OSCout/CLKin2 after power On and before register programming is an output - buffered copy of OSCin. If I will connect an external clock oscillator to these pins, there may be a signal contention here until CPU will load correct configuration to LMK04832's registers.
I'd prefer to avoid such situation.
Is there a way to change the default power on function of OSCout/CLKin2 to be ref clock input?
Any other suggestions to avoid signal contention after power on?
Thanks and best regards,
Alex
