- We would like to check if TI has a cross device to be used as a second source of Skyworks Si53306-B-GM (The Si53306-B-GM is a universal 1 : 4 low jitter clock buffer/level translator with a pin-selectable output clock signal format and divider selection), link: https://www.skyworksinc.com/en/Products/Timing/Any-Format-Clock-Buffers/Si53306-B-GM.
By this way, we can promise a second source. - In case TI doesn't have 1:1 solution, what can be the most closet item to propose?
Thank you
Ido
