Part Number: LMK00301
Does Bank A and Bank B have any phase delay if we configure both bank a and bank b with same output signal type (such as LVDS)?
What is the phase delay spec between Bank A and Bank B?
Thanks!
Thanks!
Alex,
I will get back to you by the end of the week.
Will
Alex,
As shown in the datasheet, from any two CLKouts with the same output type there will typically be a 30 ps skew, which is the propagation delay difference between any two outputs with identical output buffer type and equal loading while operating at the same supply voltage and temperature conditions. This will result in a phase difference up to 50 ps.
Will
Hi Will,
In that case there is no spec difference for the CLKouts delay from bank A and bank B.
Is that right?
