Part Number: LMKDB1108
Hello team,
On the datasheet, the input clock slew rate is minimum 0.6V/ns when differential clock. Would it be same for single ended clock, if the amplitude is 300mVpp?
Kei Kuwahara
Hello team,
Kei Kuwahara
Hello Kei,
The input slew rate needs to be 0.5x what's shown for the differential input slew rate requirement. So it needs to be 0.3V/ns. This is because for a differential signal you subtract the swig of each pin (pos - neg), which results in double the swing. Let me know if you need anything else.
Good luck,
Andrea
