Part Number: LMH1983
Hi team,
My customer mentioned It takes over 30 sec to lock PLL after TOF alignment. Is this normal behavior ?
attached the customer settings.
Hi team,
Hi Fung-san,
After they changed the initialization process, the lock time get shorter.
the initialization process is below
1.power up
2. software reset: 0x05 [7] = 0b1
3.switch settings change:0x09 [3:0] = 0010’b→ADDR 0x09 [3:0] = 0000’b(initialization process in old version datasheet )
4.TOF Alignment mode settings change:0x13 [5:4] = 10’b→Wait 500ms (More than 2 frame period)→ADDR 0x13 [5:4] = 11’b(initialization process in current version datasheet )
Before adding software reset
Set power off/on 20 times and measure lock time for each time.
Lock time less than 10 seconds: 16 times
10 to 20 seconds: 1 time
From 20 seconds: 3 times
After adding software reset
Set power off/on 30 times, and measure lock time for each time.
Lock time 10 seconds or less: 30 times
What is the reason issuing software reset after power up make the lock time shorter?
Shoo
