Other Parts Discussed in Thread: LMX2820
Hi team
1. Is it OK to use the clipped waveform as the input signal of this device. For instance, I assuem the TCXO as below. Could you tell how the device performance e.g. jitter, spurious and so on can be degrated by the clipped waveform?
2. The datasheet recommends the higer slew rate is better as the input signal. So could you confirm the following understanding is correct?
Clipped sinewave is better than sinewave.
Rectangular waveform is better than clipped sine waveform.
Noriyuki Takahashi
