Part Number: LMX2572
I am looking for the LMX2572 output power tolerance. In the datasheet, it is typically 4.5 dBm.
David
David
Hi David,
Refer to the following:
Vicente
This graph shows the output power vs Fout for 3 different out_pwr indexes.
I am looking for the accuracy of the output power at a fixed frequency and fixed out_pwr index.
For example: At about 3200Mhz and out_pwr index=31 in the graph, it shows about 2 dBm, my question is what is the tolerance around this number?
We do not specify a min and max power. This will need to be tested for your specific frequency.
Vicente
Thank you for your answer,
Maybe you have information about how it is repeatable between components, (for a fixed frequency and out_pwr index).
David
If you wish to get absolute mins/max that would be difficult given you would need to test over PVT for the fixed frequency and output power index of your choice.
Do you have a minimum/maximum requirement?
Regards ,
Vicente
