Part Number: LMK00334
Hello team,
Can this device input 3.3V single-end clock?
On datasheet, the single end input voltage swing is 2Vpp (Max).
But this device is capable of LVCMOS input, so I am confused.
Kei Kuwahara
Hello team,
Kei Kuwahara
Kei,
I will double check with our validation team, this is unclear.
Will
Kei,
The LMK00334 can only accept signals up to 2Vpp as you have shown above. This can be accomplished with a 1.8V LVCMOS signal. For 3.3V/2.5 LVMOS you have to add a 50-ohm load resistor at the receiver to attenuate the signal to meet the spec and to reduce reflections. Section 9.2.1 of the Datasheet shows exactly how to implement this. So a 3.3V LVCMOS signal will work, you just need to add the 50-ohm termination resistor.
Will
