Part Number: CDCLVP111-SP
My customer plans to use CDCLVP111-SP to distribute 6x 100MHz differential LVPECL output. In this case how much the device internal power dissipation would be at maximum?
K.Hirano
K.Hirano
K. Hirano,
I will look into this and get back to you by Wednesday.
Will
Will,
Thank you for taking care of this.
I look forward to receiving your feedbacks next Wednesday.
K.Hirano
Will,
How is it going?
When do you think you can respond?
K.Hirano
Kazuhiko,
Sorry for the delay. I have been unable to find any data on this, but I am going to see if we have a device in the lab that I can just run on the bench.
Will
Kazuhiko,
I used the EVM and terminated 6 outputs with 50 ohm terminations and had a 100MHz input signal. The EVM has two power supplies which I set to nominal voltage values of 3.3V and 2V respectively. The 3.3V supply drew .049A and the 2V supply drew .141A. This was all done at room temperature.
I hope this helps.
Will
