Part Number: LMK04828
Other Parts Discussed in Thread: , LMK04228, LMK04821, LMK04826
We are finalizing a design based on the LMK02828 to drive several ADCs clocks. When checking the possible output formats to connect the clocks, I saw a difference between data sheets. According to the old LMK04828 data sheet (SNAS703) it is possible to use HSDS with 6,8, or 10 mAs. In a newer version (I think the latest version, SNAS689A from July 2019) all references to HSDS were erased from the data sheet. I though that maybe a problem was found while using this output format and it is no longer supported. At least until I checked the common LMK0482x (SNAS605AS from May 2020) where HSDS is still, or again, there.
My question is, is this output format supported? Can I safely use it in my design?
Thank you for your help.
