Part Number: TLC555
Hi E2E,
There're some question about TLC555 design.
- For Monostable design. Is it required for input low time?
- RA=10M ohm C = 1uF, is it maximum ? or could I set to 20M ohm + 1uF?
Part Number: TLC555
Hi E2E,
Hello Janet,
When using the TLC555 in monostable mode, we recommend that the trigger pulse width should be at least 100ns.
Regarding #2, yes, you should be able to use a larger value for RA (like 20M ohm) with a 1uF timing capacitor for a longer output pulse duration.
Kind Regards,
Alex Curtis
Hi Alex,
Thank you.
How about RA=10M ohm C = 1uF, is it maximum ? or could I set to 20M ohm + 1uF?
Hi Janet,
Yes, you can use a 20M ohm resistor and 1 uF capacitor if you need a longer output pulse duration in your design.
Alex Curtis
