LMX2595EVM: LMX2595EVM
Part Number: LMX2595EVM
Other Parts Discussed in Thread: LMX2595
I am using LMX2595 evaluation board along with USB to serial board using tics pro software board to generate the frequency  from 8.0 to 15.5GHz range.
Spur performance up to 15 GHz is fine. Above 15GHz side band spur level are lifting up. Moreover when i am tuning for 1MHz step from 15.001to 15.5 GHz phase noise and spur performance is getting degrade.
Plot for different frequencies are enclosed herewith .Please suggest how to improve the performance in the mentioned range and what steps to be followed while tuning for 1MHz step .
Thanks in advance.
8.5 GHz15.03GHz15.01 GHz15.02GHz
  • Hi Manoj,
    Can you share your configuration (.tcs) file ?
    Vicente
  • I went on bench and tried ramping by 1MHz using a 15GHz direct VCO frequency and I do see a spur at at offset equal to my ramp step
    So for example if I ramped twice we expect to be at 15.002MHz and I would see a spur at 2MHz - seeing spurs in ramping mode is expected.
    Spurs will not be avoidable in ramping mode. You can reduce the spur amplitudes by reducing the charge pump current but you will not be able to eliminate them.
    Vicente
  • Hi Vicente
    Thanks for the prompt response. I have reduced the charge pump current from 15 mA to 3mA and PFD delay from 4 to 2 . I am tuning in discrete step not in ramp mode. I have seen reduction in the spur level for 10MHz step but when I am tuning for 1MHz step as you mentioned level is reduced but it is not eliminated.
    R112	0x700000
    R111	0x6F0000
    R110	0x6E0000
    R109	0x6D0000
    R108	0x6C0000
    R107	0x6B0000
    R106	0x6A0000
    R105	0x690021
    R104	0x680000
    R103	0x670000
    R102	0x660000
    R101	0x650011
    R100	0x640000
    R99	0x630000
    R98	0x620000
    R97	0x610888
    R96	0x600000
    R95	0x5F0000
    R94	0x5E0000
    R93	0x5D0000
    R92	0x5C0000
    R91	0x5B0000
    R90	0x5A0000
    R89	0x590000
    R88	0x580000
    R87	0x570000
    R86	0x560000
    R85	0x550000
    R84	0x540000
    R83	0x530000
    R82	0x520000
    R81	0x510000
    R80	0x500000
    R79	0x4F0000
    R78	0x4E0003
    R77	0x4D0000
    R76	0x4C000C
    R75	0x4B0800
    R74	0x4A0000
    R73	0x49003F
    R72	0x480001
    R71	0x470081
    R70	0x46C350
    R69	0x450000
    R68	0x4403E8
    R67	0x430000
    R66	0x4201F4
    R65	0x410000
    R64	0x401388
    R63	0x3F0000
    R62	0x3E0322
    R61	0x3D00A8
    R60	0x3C0000
    R59	0x3B0001
    R58	0x3A8001
    R57	0x390020
    R56	0x380000
    R55	0x370000
    R54	0x360000
    R53	0x350000
    R52	0x340820
    R51	0x330080
    R50	0x320000
    R49	0x314180
    R48	0x300300
    R47	0x2F0300
    R46	0x2E07FC
    R45	0x2DD0DF
    R44	0x2C1FA3
    R43	0x2BD70A
    R42	0x2A80A3
    R41	0x290000
    R40	0x280000
    R39	0x27FFFF
    R38	0x26FFFF
    R37	0x250204
    R36	0x240025
    R35	0x230004
    R34	0x220000
    R33	0x211E21
    R32	0x200393
    R31	0x1F43EC
    R30	0x1E318C
    R29	0x1D318C
    R28	0x1C0488
    R27	0x1B0003
    R26	0x1A0DB0
    R25	0x190624
    R24	0x18071A
    R23	0x17007C
    R22	0x160001
    R21	0x150401
    R20	0x14E048
    R19	0x1327B7
    R18	0x120064
    R17	0x11012C
    R16	0x100080
    R15	0x0F064F
    R14	0x0E1E40
    R13	0x0D4000
    R12	0x0C5001
    R11	0x0B0018
    R10	0x0A10D8
    R9	0x091604
    R8	0x082000
    R7	0x0740B2
    R6	0x06C802
    R5	0x0500C8
    R4	0x040A43
    R3	0x030642
    R2	0x020500
    R1	0x010808
    R0	0x00251C
    R112	0x700000
    R111	0x6F0000
    R110	0x6E0000
    R109	0x6D0000
    R108	0x6C0000
    R107	0x6B0000
    R106	0x6A0000
    R105	0x690021
    R104	0x680000
    R103	0x670000
    R102	0x660000
    R101	0x650011
    R100	0x640000
    R99	0x630000
    R98	0x620000
    R97	0x610888
    R96	0x600000
    R95	0x5F0000
    R94	0x5E0000
    R93	0x5D0000
    R92	0x5C0000
    R91	0x5B0000
    R90	0x5A0000
    R89	0x590000
    R88	0x580000
    R87	0x570000
    R86	0x560000
    R85	0x550000
    R84	0x540000
    R83	0x530000
    R82	0x520000
    R81	0x510000
    R80	0x500000
    R79	0x4F0000
    R78	0x4E0003
    R77	0x4D0000
    R76	0x4C000C
    R75	0x4B0800
    R74	0x4A0000
    R73	0x49003F
    R72	0x480001
    R71	0x470081
    R70	0x46C350
    R69	0x450000
    R68	0x4403E8
    R67	0x430000
    R66	0x4201F4
    R65	0x410000
    R64	0x401388
    R63	0x3F0000
    R62	0x3E0322
    R61	0x3D00A8
    R60	0x3C0000
    R59	0x3B0001
    R58	0x3A8001
    R57	0x390020
    R56	0x380000
    R55	0x370000
    R54	0x360000
    R53	0x350000
    R52	0x340820
    R51	0x330080
    R50	0x320000
    R49	0x314180
    R48	0x300300
    R47	0x2F0300
    R46	0x2E07FC
    R45	0x2DD0DF
    R44	0x2C1FA3
    R43	0x2BAE14
    R42	0x2A8147
    R41	0x290000
    R40	0x280000
    R39	0x27FFFF
    R38	0x26FFFF
    R37	0x250204
    R36	0x240025
    R35	0x230004
    R34	0x220000
    R33	0x211E21
    R32	0x200393
    R31	0x1F43EC
    R30	0x1E318C
    R29	0x1D318C
    R28	0x1C0488
    R27	0x1B0003
    R26	0x1A0DB0
    R25	0x190624
    R24	0x18071A
    R23	0x17007C
    R22	0x160001
    R21	0x150401
    R20	0x14E048
    R19	0x1327B7
    R18	0x120064
    R17	0x11012C
    R16	0x100080
    R15	0x0F064F
    R14	0x0E1E40
    R13	0x0D4000
    R12	0x0C5001
    R11	0x0B0018
    R10	0x0A10D8
    R9	0x091604
    R8	0x082000
    R7	0x0740B2
    R6	0x06C802
    R5	0x0500C8
    R4	0x040A43
    R3	0x030642
    R2	0x020500
    R1	0x010808
    R0	0x00251C
    15001MHz15002MHz. Configuration files text file and snapshot are attached for reference. Please suggest any parameter for improvement in the spurs
  • Hi Manoj,
    As mentioned previously - you will always see spurs in ramp mode it is unavoidable.
    You can reduce the charge current as you've done to reduce the spur amplitude but that's about it - you will not be able to eliminate the spurs all together.
    Vicente
