Part Number: LMX2491
Other Parts Discussed in Thread: LMX2492
Hi team,
In datasheet of LMX2491, Icc is 50mA typ when fPD=100Mhz for all Vcc pins. how this spec is tested? could you pls share the test settings if we want to test this spec on board?
My customer want to test power consumption of LMX2491, and they test the total current on pin6,7,8 and when power up, the current will reach to 111.8mA with VCC=VCP=3.3V, which didn't match Icc spec on datasheet.
Could you pls share any suggestion here? Thanks!
Rayna
