Unable to Generate 3.6GHz output & achieve PLL lock
Part Number: LMX2582
a. 5G
b.4.4G
c.3.6G
d.2.8G
I am able to program the LMX to generate the above required clocks and have also been able to receive PLL lock; however, I am unable to achieve PLL lock (thus the output) while configuring the LMX to generate a 3.6 GHz clock. I tried to play with the TICS Pro GUI to see if any combinations could give me the output, but unfortunately couldn't succeed in doing so.
I don't really understand the cause because I was able to successfully get a clock even while generating a 3.5GHz clock. I have attached the hex register dump, which the TICS Pro GUI itself gives out while exporting. I have tried with both low power & maximum power configurations.
Any solution/suggestion at the earliest would be of great help since I am working on a variable sampling rate application where I need to switch the sampling clock to meet the desired specification.
R70	0x460000
R69	0x450000
R68	0x440089
R64	0x400077
R62	0x3E0000
R61	0x3D0001
R59	0x3B0000
R48	0x3003FD
R47	0x2F08FF
R46	0x2E3F20
R45	0x2D0000
R44	0x2C0000
R43	0x2B0000
R42	0x2A0000
R41	0x2903E8
R40	0x280000
R39	0x278104
R38	0x260012
R37	0x254000
R36	0x240001
R35	0x23021F
R34	0x22C3EA
R33	0x212A0A
R32	0x20210A
R31	0x1F0001
R30	0x1E0034
R29	0x1D0084
R28	0x1C2924
R25	0x190000
R24	0x180509
R23	0x178842
R22	0x162300
R20	0x14012C
R19	0x130965
R14	0x0E018C
R13	0x0D4000
R12	0x0C7001
R11	0x0B0018
R10	0x0A10D8
R9	0x090302
R8	0x081084
R7	0x0728B2
R4	0x041943
R2	0x020500
R1	0x010808
R0	0x00231C
R70	0x460000
R69	0x450000
R68	0x440089
R64	0x400077
R62	0x3E0000
R61	0x3D0001
R59	0x3B0000
R48	0x3003FD
R47	0x2F08DF
R46	0x2E1F20
R45	0x2D0000
R44	0x2C0000
R43	0x2B0000
R42	0x2A0000
R41	0x290001
R40	0x280000
R39	0x278104
R38	0x260012
R37	0x254000
R36	0x240001
R35	0x23021B
R34	0x22C3EA
R33	0x212A0A
R32	0x20210A
R31	0x1F0001
R30	0x1E0034
R29	0x1D0084
R28	0x1C2924
R25	0x190000
R24	0x180509
R23	0x178842
R22	0x162300
R20	0x14012C
R19	0x130965
R14	0x0E018C
R13	0x0D4000
R12	0x0C7001
R11	0x0B0018
R10	0x0A10D8
R9	0x090302
R8	0x081084
R7	0x0728B2
R4	0x041943
R2	0x020500
R1	0x010808
R0	0x00231C
