Part Number: CDCLVP111-SP
I have a question about the Vdo spec in the datasheet below.
From common sense, the differential output voltage swing Vdo definition should be as follows.
However, looking at the following E2E thread, I am confused.
It says the differential output voltage swing Vdo definition is as follows.
Which is true.
If the E2E is correct, TI should revise the datasheet and change the unit from mV to mVpp at least to avoid confusion.
K.Hirano
