Dear
Now I use CDCE6214, Need to use 24MHZ frequency dojubling of LVCMOS to 144MHz of LVDS, Could you help to configure the CDCE6124 is I2C mode to configure 144MHZ Clock output Script file , thanks
Dear
Liu,
To confirm, you need to take a 24MHz LVCMOS input to the CDCE6214 and generate both a 144MHz clock and a 74.25MHz clock? Generating both of these frequencies from a single CDCE6214 is not possible, as 74.25MHz requires a separate frequency domain.
We can provide the configuration for 144MHz differential from 24MHz LVCMOS tomorrow.
Kadeem
Liu,
Kadeem
Hi Kadeem
Sorry, I misstated.
1. We need to input a 24MHZ LVCMOS clock into two different CDCE6214, one output 74.25MHZ clock of LVDS, and another output 144MHZ clock of LVDS.
2. The power supply of both CDCE6214RGER chips is 1.8V, please help to check the SCH whether there is any problem . The schematic diagram is as follows
Liu,
I have attached the two configuration files here. Please let me know if a larger swing is required, and we can change the output format from LP-HCSL to LVDS.
CDCE6214_24MHz_In_144MHz_Out.tcs
CDCE6214_24MHz_In_74p25MHz_Out.tcs
For the schematic review, I have two notes:
Kadeem
