I have 120MHz RF Frequency with 10 DBm input power. can i give this frequency on INP1 and take output from all channel with the same power out. please let me know if is there any losses occur.
Khagesh
Khagesh
Hi Khagesh,
This is an LVDS output buffer thus the output swing is typically as follows:
10dBm is 2Vpp.
LVPECL single ended output swing is around 800mV which differentially is 1.6V.
Vicente
so you mean we will have to use LVPECL IC?
and what about output power. will i get 10dBm output power on all channel ?
Hi Khagesh,
You will Not get 10dBM.
As mentioned, you will get a little over 8dBM.
What is your receiver input requirements?
Do you require 10dBm minimum?
Vicente
