Part Number: LMK1D2102
Good day. I am designing a main board PCB for a test bench, and I have a question regarding the LMK1D2102RGTR:
Can I control the enable signal from an ADIO PXIe instrument the way I show you in the attached image? I want it to be at GND by default with the pull-down resistor (all outputs disabled) and when I want to enable OUT0 and OUT1 the ADIO will put the signal "DIO_CLK_EN" at 3V3 (high).
Is that correct?
Thank you very much,
Jorge.
