Part Number: LM555
Greetings,
If on a good old 555, in a monostable assembly, the negative trigger pulse, received at around 500 Hz, is longer than the monostable output, as decided by R-C values, what shall happen ? Shall there be a continuous output delivered, or, regardless of the length of the trigger, the output shall have the length decided by the R and C values only ? In other words, regardless of the length of the trigger pulse, the monostable output shall have a calculated fixed length, as per R and C values.
Many thanks and best regards !
