Need design support for this part.
- Is there a reference design/schematic available that uses this part?
- The data sheet doesn’t specify what to do with the CPout pin (pin number 42)… do I leave it open or do I terminate in some fashion?
- There are 13 VCC pins associated with this device… should they all be fed from the same 3V3 voltage rail or do any of them (i.e. VCC9, power supply for the PLL) require special handling (i.e. pi filter, etc)?
