Part Number: CDCE913
Hi team,
The recent datasheet update included changes to the power-up sequence.
Why was this modified?
I need to understand the impact on existing systems, so please explain the background for this change.
Ryu.
Hi team,
Ryu.
Hi Ryu,
We recommend that the input clock to CDCE913 is running before VDD is on.
Sandra
Hi Sandra,
Thank you for your reply.
What I want to know is why the change was made.
Not how the change was made.
Ryu.
Hi Ryu,
Sorry i misread the question.
In certain applications the PLL would not lock if the clock input was a static signal to avoid running into this issue ideally the input clock needs be on before VDD. Also avoid long delays between turning on the input clock after turning on VDD, keep the delay under 1 second.
Sandra
