LMX2694EPEVM: Return Request - USB2ANY: Unable to upgrade Firmware (SO 523592)
Part Number: LMX2694EPEVM
Other Parts Discussed in Thread: BQ25180, USB2ANY
Hello TI Support Team,
The customer has reached out to TI and received the request to return the EVM to TI. Please find the link below for the TI 2E2 forums regarding this case and advise on an RMA and return instructions. Thank you.
TI part#LMX2694EPEVM
Mouser PO: 029-FN679
Qty: 1 pc
Lot code: 5021558KRY
TI E2E forum: https://e2e.ti.com/support/amplifiers-group/amplifiers/f/amplifiers-forum/1103792/usb2any-unable-to-upgrade-firmware
Dan Lee
  • Hi Dan,
    The link you have provided is for BQ25180 device, not LMX2694.
  • Hello Noel,
    Sorry but the issue is related on part#LMX2694EPEVM. The thread I provided was posted by the customer and I am not sure why it was under BQ25180 device. The customer found an issue with USB2ANY which is one of contens from LMX2694EPEVM. I have checked with the customer that even if the customer attempt to verify the remaining components, the operational status can only be confirmed through compatibility testing between the USB2ANY module and the firmware. But, the error occurred from the initial attempt, they are unable to proceed the verification for whole part#LMX2694EPEVM.
    So, I would like to submit a return request to TI for part#LMX2694EPEVM as recommended per TI Expert(Arelis Guerrero). Please advise. Thank you.
    Best regarsd,
    Dan Lee
  • Hi Dan,
    I am ok for the return, please work out with our Customer Support for RMA.
