LMK6D: LMK6DA15625ADLFR enable pin
Part Number: LMK6D
For the PN:  LMK6DA15625ADLFR, is Pin 1 and Pin 2 both Standby pins?   Is Pin 1 an Active LOW standby pin, where if you set pin 1 to a Logic HI, then it will enable the output for the device?  And Pin 2 can be left floating if we want to use Pin 1 as the controller pin to put the devce into Standby (Logit LO), or Active Mode (Logic Hi).
Just clarifying.!
