Part Number: LMK5B33216
Hi TI Team,
We are currently evaluating the LMK5B33216 for a new project. To optimize our mass production line and SMT process efficiency, we would like to pre-program the configuration profile (generated from TICS Pro) into the chip's internal EEPROM prior to SMT board mounting.
Regarding this offline pre-programming approach, we have the following two questions:
Official Socket Support: Does TI offer or recommend an official external programming socket/adapter for the LMK5B33216 (64-pin QFN package)? If yes, could you please provide the corresponding part number or orderable model for the socket wrapper/adapter?
Pre-Programming & NVM Requirements: When programming the internal EEPROM offline before SMT, are there any specific hardware or software constraints we need to follow? Specifically, please advise on:
VDD Supply Voltage: Is there a specific voltage restriction or higher programming voltage requirement (e.g., for NVM programming) compared to normal operation?
Minimum Pin Connections: Which hardware pins must be connected to the programmer interface (e.g., VDD, GND, I2C/SPI lines, RESET, or specific control pins)?
Programming Sequence/Registers: Are there any specific register unlock sequences, non-volatile memory counter (
NVMCNT) handling, or CRC verification flows that must be executed to successfully lock the configuration into the EEPROM?
Any documentation, application notes, or guidelines regarding off-board programming for this device family would be highly appreciated.
Thank you for your support.
Daniel
