Part Number: LMK04832
We are experiencing an issue with the LMK04832 that has us confused and wondering if you could provide some assistance.
We have a design using the LMK04832 on a customboard where PLL1 is used in a jitter cleaner configuration at 128 MHz and PLL2 is disabled. The device is configured in 0-delay mode with internal feedback on DCLKout6. CLKOut11 and CLKout13 have equal dividers, which I have set as 4 for the purposes of this example (to avoid the 2/3 divide sync complications).
We are finding that upon SYNC, either by external PIN, or SPI control. There is a 1/4 of 1 DEVCLK delay between the two divided clocks (see attached photo). Even if I put the divider to 1 and SYNC there is a quarter of a DEVCLK delay (Attached photo of this too)? I wouldn't have thought this is possible as there is only the DEVCLK involved in dividing, or at most a 1/2 period DEVCLK if an inv
ersion.
The pictures attached are from running on the LMK04832EVM (but at 122.88 MHz of the on-board VCXO). Trace 1 is the input REF of 122.88 and traces 2 and 3 are Outclk11 and 13 respectively.
I've tried every option I can think of. All digital delays are powered down, the design only uses DEVCLK and not SYSREF path. SYNC is aoccuring as I can see the loop glitch and settle if I turn oneshot off. I've eliminated the obvious like cable difference, and checking CRO alignment on channels.
I have a second LMK04832EVM and behaviour is identical on this second board.
I've attached the .tcs file for the test design.
I'd appreciate any help with how this is possible to have a quarter clock difference, and what needs to be done to get the output divided clocks synchronosed in this configuration.
Thanks and Regards
Paul R
