Part Number: LMK03318
We have a signal processing card which interfaces via a PCIe Gen 1 x 1 Lane to a PC. We are looking for a device to take the PCIe 100 MHz reference clock from the socket as its' input and translate this to a single 125 MHz output signal to drive a PCIe SERDES in an FPGA. The significant complication is that the PCIe 100 MHz reference clock will have the standard PCIe-mandated frequency dither which involves a frequency variation of 0 to - 0.5% at a rate of up to 33 KHz, typically a triangular modulation. That means any internal PLL in the device must have a loop bandwidth of at least 1 MHz.
The LMK03318 seems to be a possible candidate although the data-sheet suggests that at this loop bandwidth there may be significant issues with the level of synthesiser spurs on the output.
Any comments on the suitability or not of this device for this purpose would be much appreciated. If that included possible alternative devices that would be great too.
(As background, this is a re-design to replace a redundant part ISC874001, data-sheet attached :-
ICS 874001 Clock Jitter Attenuator.pdf )
