Part Number: BQ32000
Hello team,
Customer newly received BQ32000DR ICs are causing their system failures at the production site. Older batches of the same IC function correctly on identical PCBs. The customer requests clarification on the possible root cause and the meaning of each line of the IC top marking.
This existing RTC design has been made for a long time, and no issue report before. However, it looks the newly received device found the issue. thanks.
Can you provide the date codes from both the working (old) and failing (new) BQ32000DR batches? And what's the possible root cause? Thanks.
Brian
