LMKDB1104: Register question
Part Number: LMKDB1104
Hi team,
We got some question about the datasheet, please kindly share some input.
  1. What does the meaning of SLEWRATE_SEL_CLK2_MSB? Default is 1, what happen if set to 0? image.png
  2. Does our device support saving config in the device?I can only find save config in PD. Does that mean power up back the setting still remain?
  • Hi Oliver,
    SLEWRATE_SEL_CLKx_LSB and SLEWRATE_SEL_CLKx_MSB can be used to pick from 4 slew rate options for a given output CLKoutX. You can program desired slew rate values (from highest to lowest) into the SLEWRATE_OPT_x registers, and then select from the SLEWRATE_OPT_X registers using SLEWRATE_SEL_CLKx_LSB/MSB for a given output.
    Also, our device does not support nonvolatile memory. Upon power cycling, you must reprogram the device. When coming out of power down mode, however, the configuration is stored.
    Michael
