Part Number: CDCE6214
Would you be able to tell me how much additive jitter the CDCE6214 would have if I had a 40Mhz input that was connected either to a LVCMOS output or to a LVDS output without using the pll?
Hi Daniel,
The only additive RMS jitter specification we have characterized for this part is for the test condition shown below:
Here are some additive jitter numbers I observed when testing on a CDCE6214-Q1EVM with a 40MHz input on PRIREF, calculated with J_add = sqrt(J_out^2 - J_in^2). Keep in mind this is a spot check and not a full characterization:
Jaryd
I have a follow up question regarding the CDCE6214. Due to the additive jitter you listed above I am looking at another way to go with this design but it would require using zero delay mode for the CDCE6214 which adds more questions.
The configuration of the CDCE6214 would be as follows:
40 MHz LVCMOS reference into PRIREF_P, with PRIREF_N grounded.
OUT1_P/N: 160 MHz LVDS output to the receiving device.
OUT4: 40 MHz LVCMOS output returned to SECREF_P as external feedback, with SECREF_N grounded.
1.8 V supplies and integer operation.
The same external 40 MHz source also drives our receiving device through a separate, matched buffer output. At the receiver, each 40 MHz rising edge must align with a 160 MHz rising edge within ±535 ps.
We selected OUT1/OUT4 because they are a matched pair. However, we will use different output formats and divider ratios.
The datasheet specifies ±400 ps input-to-output delay variation in ZDB mode with 25 MHz LVCMOS input and output. Separately, it lists 400 ps LVCMOS-to-differential output skew with equal divider settings.
Could you clarify:
Does the ±400 ps ZDB delay-variation specification apply with our 40 MHz LVCMOS reference and feedback? What nominal offset and variation should we expect, including device, supply, temperature and restart/relock variation?
What is the signed delay difference between OUT1 at 160 MHz LVDS and OUT4 at 40 MHz LVCMOS? How much is a fixed offset, and how much varies with device, supply and temperature? Does the published 400 ps mixed-format skew apply with these different divider ratios?
Could we compensate the nominal output delay difference by adding a fixed delay to the external feedback path? Would adding feedback delay move the 160 MHz output in the required direction, and what residual worst-case phase error should we expect after compensation? Is any sufficiently fine internal adjustment available in integer mode?
Can you recommend a frequency plan and initialization/SYNC sequence that gives repeatable alignment?
Our main concern is whether the complete reference-to-160 MHz phase error, after fixed compensation, can fit comfortably within ±535 ps while leaving some margin for external buffer and PCB mismatch. Any characterization data for this configuration would be helpful.
Hi Daniel,
I don't have the EVM setup with me currently; I will investigate this and get back to you with data on your setup next week after the holiday.
Jaryd
