CDCE6214: CDCE6214 application
Part Number: CDCE6214
Hi sir,
Customer is evaluating CDCE6214, when using TICS Pro simulation and checking datasheet. Here are few questions:
(1) Frequency Plan check output freq display
  • Input: PRI = 25 MHz (+25 ppm)
  • Expected output: 156.25 MHz (+25 ppm) & 125 MHz (+25 ppm)
  • Question is : In TICS Pro executes Calculate Frequency Plan, the Vco = 2500.0625 MHz, as attached pic. It's not rounded, so after calculation, 156.25 MHz display ~156.253907 MHz
  • Is it just becuase TICS Pro Interface and Rounded result, or it's chip limitation? In this setting, the real output is exact 156.25390625 MHz  and able to work normally?
(2) Output Swing & SoC LVPECL receving side impedence suggestion
  • Receiving side: Back side SoC pulse input is LVPECL differential input, requres differential Vpp in  600 mV ~ 1600 mV, so customer add AC coupling cap
  • Question A: in LVDS mode: Datasheet says the  LVDS Vod Typical is 0.3V (Max 0.45V), turns differencial peak-peak is ~ 600 mVpp, which is under SoC spec low boundry. Is there any way we can adjust  LVDS swing to increase? If increase LVDS swing, is there any caution on waveform distortion, jitter, or any?
  • Question B (change to LP-HCSL mode) If change to LP-HCSL + AC coupling to connect SoC, would LP-HCSL swing over SoC 1600 mVpp spec? Can adjust lower in TICS Pro to let LP-HCSL  swing smaller? Besides, if changed to LP-HCSL mode, is there any caution?
Thanks!
